New interface
Reports (Research report)
Combining blockwise and multi-coefficient stepwise approches in a general framework for online audio source separation
Abstract : This article considers the problem of online audio source separation. Various algorithms can be found in the literature, featuring either blockwise or stepwise approaches, and using either the spectral or spatial characteristics of the sound sources of a mixture. We offer an algorithm that can combine both stepwise and blockwise approaches, and that can use spectral and spatial information. We propose a method for pre-processing the data of each block and offer a way to deduce an Equivalent Rectangular Bandwith time-frequency representation out of a Short-Time Fourier Transform. The efficiency of our algorithm is then tested for various parameters and the effect of each of those parameters on the quality of separation and on the computation time is then discussed.
Document type :
Complete list of metadata
Cited literature [35 references]  Display  Hide  Download
https://hal.inria.fr/hal-01186948
Contributor : Emmanuel Vincent Connect in order to contact the contributor
Submitted on : Tuesday, August 25, 2015 - 4:38:55 PM
Last modification on : Thursday, October 27, 2022 - 3:38:29 AM
Long-term archiving on: : Thursday, November 26, 2015 - 2:04:40 PM
File
RR-8766.pdf
Identifiers
  • HAL Id : hal-01186948, version 1
Citation
Laurent S. R. Simon, Emmanuel Vincent. Combining blockwise and multi-coefficient stepwise approches in a general framework for online audio source separation. [Research Report] RR-8766, Inria. 2015, pp.18. ⟨hal-01186948⟩
Share
Metrics
Record views
390
Files downloads
240
