EOLE: Toward a Practical Implementation of Value Prediction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Micro Année : 2015
Arthur Perais
André Seznec
A new architecture, Early/Out-of-Order/Late Execution (EOLE), leverages value prediction to execute a significant number of instructions outside the out-of-order engine. This approach reduces the issue width, which is a major contributor to both out-of-order engine complexity and the register file port requirement. This reduction paves the way for a truly practical implementation of value prediction.
MI_MicroSI-2015-02-0057_Perais.pdf (467.84 Ko) Télécharger le fichier
hal-01193287 , version 1 (07-09-2015)
Arthur Perais, André Seznec. EOLE: Toward a Practical Implementation of Value Prediction . IEEE Micro, 2015, Micro's Top Picks from the 2014 Computer Architecture Conferences, 35 (3), pp.114 - 124. ⟨10.1109/MM.2015.45⟩. ⟨hal-01193287⟩
380 Consultations
414 Téléchargements
