Impedance Transmission Conditions for the Electric Potential across a Highly Conductive Casing
We present Impedance Transmission Conditions (ITCs) for the electric potential in the framework of borehole through-casing resistivity measurements. Such ITCs substitute the part of the domain corresponding to a highly conductive casing. The naturally small thickness of the casing makes it ideal for exhibiting ITCs. We numerically observe the delivered order of accuracy.
aralarerdozain.pdf (408.56 Ko)
Télécharger le fichier
wavesconf.pdf (20.09 Mo)
