Low complexity on-chip distributed DC-DC converter for low power WSN nodes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Supply voltage scaling has become an important low power technique to reduce the power consumption of sub-nanometer technologies. Instead of supplying same magnitude of Vdd for the whole chip, multi-Vdd and Dynamic Voltage Scaling (DVS) have been advocated for the enhanced power efficiency at the cost of added complexity. In this paper, we present a low area, low power on-chip DC-DC converter suitable for low power Wireless Sensor Network (WSN) nodes. This converter offers the flexibility to perform micro-level DVS for various blocks of the system. Peak efficiency of 90% has been achieved and the proposed DC-DC converter takes utmost delay of 30μs to switch between the different output voltages.
Fichier non déposé
hal-01196987 , version 1 (10-09-2015)
Rengarajan Ragavan, Cédric Killian, Olivier Sentieys. Low complexity on-chip distributed DC-DC converter for low power WSN nodes. NEWCAS 2015 - New Circuits and Systems Conference, Jun 2015, Grenoble, France. pp.4, ⟨10.1109/NEWCAS.2015.7182118⟩. ⟨hal-01196987⟩
193 Consultations
0 Téléchargements
