Conference papers
Lyapunov Stability Analysis of a Model Describing Hematopoiesis
Abstract : The knowledge of Lyapunov-Krasovskii functionals offers strong advantages when investigating the local or global stability properties of equilibrium points of a system with delay. Unfortunately, in many cases the construction of these functionals is not an easy task. This is the case of the model describing hematopoiesis, which is a nonlinear system with distributed delays, which, according to some conditions, admits one or two equilibrium points. By contrast with approaches already used to study this model, we analyze the stability properties of its equilibrium points by constructing Lyapunov-Krasovskii functionals of two types.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01202179
Contributor : Frederic Mazenc Connect in order to contact the contributor
Submitted on : Saturday, September 19, 2015 - 11:00:02 AM
Last modification on : Saturday, May 1, 2021 - 3:46:36 AM
Identifiers
Citation
Walid Djema, Frédéric Mazenc, Catherine Bonnet. Lyapunov Stability Analysis of a Model Describing Hematopoiesis. 14th annual European Control Conference - ECC 2015, Jul 2015, Linz, Austria. pp.6, ⟨10.1109/ecc.2015.7330947⟩. ⟨hal-01202179⟩
Share
Metrics
Les métriques sont temporairement indisponibles
