Evolutionary clustering for categorical data using parametric links among multinomial mixture models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Econometrics and Statistics Année : 2017
In this paper, we propose a novel evolutionary clustering method for temporal categorical data based on parametric links among multinomial mixture models. Besides clustering, our main goal is to interpret the evolutions of clusters over time. To this aim, first we propose the formulation of a generalized model that establishes parametric links among two multinomial mixture. Afterward, different parametric sub-models are defined in order to model typical evolutions of the clustering structure. Model selection criteria allow to select the best sub-models and thus to guess the clustering evolution. For the experiments, first we evaluate the proposed method with synthetic temporal data. Next, we apply it to analyze the annotated social media data. Results show that the proposed method is better than the state-of-the-art based on the common evaluation metrics. Additionally, it can provide interpretation about the temporal evolution of the clusters.
PLMM.pdf (2.3 Mo) Télécharger le fichier
hal-01204613 , version 1 (24-09-2015)
hal-01204613 , version 2 (21-03-2016)
hal-01204613 , version 3 (27-02-2019)
Md Abul Hasnat, Julien Velcin, Stephane Bonnevay, Julien Jacques. Evolutionary clustering for categorical data using parametric links among multinomial mixture models. Econometrics and Statistics , 2017, 3, pp.141-159. ⟨10.1016/j.ecosta.2017.03.004⟩. ⟨hal-01204613v3⟩
601 Consultations
611 Téléchargements
