Computing least squares condition numbers on hybrid multicore/GPU systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
We present an efficient computation for least squares conditioning or estimates of it. We propose performance results using new routines on top of the multicore-GPU library MAGMA. This set of routines is based on an efficient computation of the variance-covariance matrix for which, to our knowledge, there is no implementation in current public domain libraries LAPACK and ScaLAPACK.
hal-01204804 , version 1 (24-09-2015)
Marc Baboulin, Jack Dongarra, Rémi Lacroix. Computing least squares condition numbers on hybrid multicore/GPU systems. Interdisciplinary Topics in Applied Mathematics, Modeling and Computational Science, 117, Springer International Publishing, 2015, 978-3-319-12306-6. ⟨10.1007/978-3-319-12307-3_6⟩. ⟨hal-01204804⟩
168 Consultations
0 Téléchargements
