Online Object Tracking with Proposal Selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Karteek Alahari
Cordelia Schmid
  • Fonction : Auteur
  • PersonId : 831154
Tracking-by-detection approaches are some of the most successful object trackers in recent years. Their success is largely determined by the detector model they learn initially and then update over time. However, under challenging conditions where an object can undergo transformations, e.g., severe rotation, these methods are found to be lacking. In this paper, we address this problem by formulating it as a proposal selection task and making two contributions. The first one is introducing novel proposals estimated from the geometric transformations undergone by the object, and building a rich candidate set for predicting the object location. The second one is devising a novel selection strategy using multiple cues, i.e., detection score and edgeness score computed from state-of-the-art object edges and motion boundaries. We extensively evaluate our approach on the visual object tracking 2014 challenge and online tracking benchmark datasets, and show the best performance.
paper.pdf (2.91 Mo) Télécharger le fichier
hal-01207196 , version 1 (30-09-2015)
Yang Hua, Karteek Alahari, Cordelia Schmid. Online Object Tracking with Proposal Selection. ICCV - IEEE International Conference on Computer Vision, Dec 2015, Santiago, Chile. pp.3092-3100, ⟨10.1109/ICCV.2015.354⟩. ⟨hal-01207196⟩
647 Consultations
2317 Téléchargements
