Stabilization of Chain of Integrators with Arbitrary Order in Finite-time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A control algorithm for finite-time stabilization of a chain of integrators with arbitrary order is introduced. The method is based on Implicit Lyapunov Function (ILF) approach with applying properties of homogeneous systems. Scheme of control parameter tuning is presented in Linear Matrix Inequality (LMI) form. The method is simple in implementation and does not assume any additional computational on-line procedures that is an improvement with respect to [8], [11]. The theoretical results are supported by numerical simulations.
Automatique
CDC15_0249_FI.pdf (239.12 Ko) Télécharger le fichier
hal-01212600 , version 1 (06-10-2015)
  • HAL Id : hal-01212600 , version 1
Konstantin Zimenko, Andrey Polyakov, Denis Efimov. Stabilization of Chain of Integrators with Arbitrary Order in Finite-time. 54th conference on Decision and Control 2015, IEEE, Dec 2015, Osaka, Japan. ⟨hal-01212600⟩
190 Consultations
409 Téléchargements
