Conference papers
Distributed, Asynchronous, Numerical and Adaptive computing: from neurons to behavior
Nicolas P. Rougier 1, 2, 3
3 Mnemosyne - Mnemonic Synergy
LaBRI - Laboratoire Bordelais de Recherche en Informatique, Inria Bordeaux - Sud-Ouest, IMN - Institut des Maladies Neurodégénératives [Bordeaux]
Abstract : Computational models of the brain exist at several different levels of description, from the very precise modelling of a unique spiking neuron, taking into account ion channels and/or dendrites spatial geometry, up to the modelling of very large assemblies of neuron that express complex dynamic interactions. I'm interested in a mesoscopic approach of the brain where the computational paradigm is grounded on the notion of a unit that is essentially a set of time dependent values varying under the influence of other units via adaptive weighted connections. The evolution of the units' value and weights are simply defined by a set of differential equations. This is a strongly constrained framework that has been designed such as to avoid any modeling artifact like a central supervisor or a homunculus. If some properties are to emerge from our models, we want to make sure they are properties of the model as opposed to properties of the software that run the simulation.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01213784
Contributor : Nicolas P. Rougier Connect in order to contact the contributor
Submitted on : Friday, October 9, 2015 - 4:43:10 PM
Last modification on : Saturday, June 25, 2022 - 7:41:15 PM
Annex
Identifiers
  • HAL Id : hal-01213784, version 1
Collections
Citation
Nicolas P. Rougier. Distributed, Asynchronous, Numerical and Adaptive computing: from neurons to behavior. BioComp workshop, GDR BioComp, Oct 2015, Saint Paul de Vence, France. ⟨hal-01213784⟩
Share
Metrics
Record views
129
Files downloads
20
