New interface
Journal articles
Axisymmetric eddy current inspection of highly conducting thin layers via asymptotic models
Houssem Haddar 1 Zixian Jiang 1
1 DeFI - Shape reconstruction and identification
CMAP - Centre de Mathématiques Appliquées - Ecole Polytechnique, Inria Saclay - Ile de France
Abstract : Thin copper deposits covering the steam generator tubes can blind eddy current probes in non-destructive testings of problematic faults and are therefore important to be identified. Existing methods based on shape reconstruction using eddy current signals encounter difficulties of high numerical costs due to the layer's small thickness and high conductivity. In this article, we approximate the axisymmetric eddy current problem with some appropriate asymptotic models using effective transmission conditions representing the thin deposits. In these models, the geometrical information related to the deposit is transformed into parameter coefficients on a fictitious interface. Standard iterative inversion algorithm is then applied to the asymptotic models in order to reconstruct the thickness of the thin copper layers. Numerical tests both validating the asymptotic model and benefit of the inversion procedure are provided.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01214308
Contributor : Houssem Haddar Connect in order to contact the contributor
Submitted on : Sunday, October 11, 2015 - 9:32:23 PM
Last modification on : Wednesday, August 24, 2022 - 9:40:06 AM
Long-term archiving on: : Tuesday, January 12, 2016 - 10:40:15 AM
File
ReconstrAsymp.pdf
Identifiers
  • HAL Id : hal-01214308, version 1
Citation
Houssem Haddar, Zixian Jiang. Axisymmetric eddy current inspection of highly conducting thin layers via asymptotic models. Inverse Problems, 2015. ⟨hal-01214308⟩
Share
Metrics
Record views
225
Files downloads
160
