Journal articles
Unsupervised Learning of Generalized Gamma Mixture Model with Application in Statistical Modeling of High-Resolution SAR Images
Abstract : The accurate statistical modeling of synthetic aperture radar (SAR) images is a crucial problem in the context of effective SAR image processing, interpretation and application. In this paper a semi-parametric approach is designed within the framework of finite mixture models based on the generalized Gamma distribution (GΓD) in view of its flexibility and compact form. Specifically, we develop a generalized Gamma mixture model (GΓMM) to implement an effective statistical analysis of high-resolution SAR images and prove the identifiability of such mixtures. A low-complexity unsupervised estimation method is derived by combining the proposed histogram-based expectation-conditional maximization (ECM) algorithm and the Figueiredo-Jain algorithm. This results in a numerical maximum likelihood (ML) estimator that can simultaneously determine the ML estimates of component parameters and the optimal number of mixture components. Finally, the state-of-the-art performance of this proposed method is verified by experiments with a wide range of high-resolution SAR images. Index Terms Synthetic aperture radar (SAR) images, finite mixture model, generalized Gamma distribution, expectation-conditional maximization (ECM) algorithm, minimum message length (MML), probability density function estimation , unsupervised learning.
Document type :
Journal articles
Complete list of metadata
Cited literature [45 references]  Display  Hide  Download
https://hal.inria.fr/hal-01217654
Contributor : Vladimir Krylov Connect in order to contact the contributor
Submitted on : Tuesday, October 20, 2015 - 3:28:58 PM
Last modification on : Wednesday, February 2, 2022 - 3:51:02 PM
Long-term archiving on: : Friday, April 28, 2017 - 8:10:58 AM
File
li_tgrs2015.pdf
Identifiers
  • HAL Id : hal-01217654, version 1
Collections
Citation
Heng-Chao Li, Vladimir A. Krylov, Ping-Zhi Fan, Josiane Zerubia, William J. Emery. Unsupervised Learning of Generalized Gamma Mixture Model with Application in Statistical Modeling of High-Resolution SAR Images. IEEE Transactions on Geoscience and Remote Sensing, Institute of Electrical and Electronics Engineers, 2016, 54 (4), pp.2153-2170. ⟨hal-01217654⟩
Share
Metrics
Record views
303
Files downloads
625
