New interface
Journal articles
Distributions of traces of Frobenius for smooth plane curves over finite fields
Abstract : In a previous article, we obtained data on the distribution of traces of Frobenius of non-hyperelliptic genus 3 curves over small finite fields. In the present one, we give a heuristic explanation of these data, by extrapolating from results on the distribution of traces of Frobenius for plane curves whose degree is small with respect to the cardinality of their finite base field. In particular, our methods shed some new light on the asymmetry of the distribution around its mean value, which is related to the Serre obstruction.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01217995
Contributor : Benjamin Smith Connect in order to contact the contributor
Submitted on : Tuesday, October 20, 2015 - 2:16:01 PM
Last modification on : Friday, November 18, 2022 - 9:26:31 AM
Links full text
Identifiers
Citation
Reynald Lercier, Christophe Ritzenthaler, Florent Rovetta, Jeroen Sijsling, Benjamin Smith. Distributions of traces of Frobenius for smooth plane curves over finite fields. Experimental Mathematics, 2019, 28 (1), pp.39-48. ⟨10.1080/10586458.2017.1328321⟩. ⟨hal-01217995⟩
Share
Metrics
Record views
650
