Research on Automatic Irrigation Algorithm of Strawberry Greenhouse Based on PLC
In order to realize efficient water-saving irrigation of strawberry
greenhouse in precision agriculture, the paper proposed an automatic
irrigation algorithm based on fuzzy comprehensive evaluation irrigation
based on PLC and the configuration software, and build a remote control
system. By measuring the greenhouse soil parameters and strawberry soil
moisture data to determine the upper and lower limits of irrigation and
set buried position of moisture sensors. Use fuzzy comprehensive
evaluation method to handle multi-sensor data, and develop an automatic
irrigation control algorithm that depends on the strawberry irrigation
system. Set up a C / S mode of automatic irrigation control system
through the 3G network and the remote computer. The experimental results
show that the algorithm is reasonable and reliable, and can be well
adapted to the strawberry greenhouse. The automatic irrigations meet the
steady demands for real-time performance and high scalability. The
irrigation automation of strawberry greenhouse provides a theoretical
and practical basis for intelligent irrigation of strawberry
greenhouse.
