Abstract : Drought is a major disaster that Beijing agricultural systems faced
with. The risk of drought disasters is a result of drought disaster
together with vulnerability, the result of drought disaster only
appeared in post-disaster, before the disaster occurred, we need to make
some research on drought vulnerability that Beijing agricultural systems
faced with, we choose VAM (vulnerability assessment method) that consist
of three drought elements: exposure, sensitivity and adaptive capacity,
based on two kinds of analytic hierarchy process method to determine the
weight of each factors. try to verify the results of agricultural
drought indicator system through the spatial distribution map of soil
moisture, as well as explore the key factors that influence Beijing
agricultural drought vulnerability.
https://hal.inria.fr/hal-01220850 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, October 27, 2015 - 8:29:34 AM Last modification on : Wednesday, January 17, 2018 - 10:45:36 AM Long-term archiving on: : Thursday, January 28, 2016 - 10:24:29 AM
