Abstract : In order to study the interaction between urea and mechanical
structure, using direct shear test method, the shear modulus of urea was
tested by C-LM4 computer measurement and control shear force measuring
instrument. The obtained test curves show that: extrusion makes the
binding strength between urea molecules reduce, shear force peak emerge,
then decline rapidly; as rolling granules and surrounding granules
formed compression and friction resistance in contact surface along the
direction of shear, shear force emerges rise again. At the test
temperature 22℃, ambient humidity 45%, the density of urea
granules 1.33 ×
103kg/m3, the
values range of shear modulus of urea granules was measured, which was
0.23- 0.3GPa.
https://hal.inria.fr/hal-01220906 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, October 27, 2015 - 9:58:57 AM Last modification on : Wednesday, January 17, 2018 - 10:44:15 AM Long-term archiving on: : Thursday, January 28, 2016 - 10:32:48 AM
Jinfeng Wang, Detang Zou, Jinwu Wang, Wei Zhou. Testing and Analysis of the Shear Modulus of Urea Granules. 7th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2013, Beijing, China. pp.137-144, ⟨10.1007/978-3-642-54344-9_17⟩. ⟨hal-01220906⟩
