Application of Modbus Protocol Based on μC /TCPIP in Water Saving Irrigation in Facility Agricultural
As long as the deepen application of the Intelligent equipment
technology in the Water Saving Irrigation, a hot topics in research is
coming out, that is how to increase the proportion of the efficiency and
output for the high tech facility in manufacture. The Modbus protocol
based on u C/TCPIP will play an important role in the Water Saving
Irrigation application system, comparing to the others, it has such
advantages of the Reliability of communication technology and real-time
performance. After analyzing components of Modbus/TCP protocol, we
applied it on real-time u C/OS-II kernel and ARM7 software and hardware
and hardware environment with Modbus frame embedded in TCP frame. Test
results show that Modbus/TCP protocol can achieve industrial standards.
The protocol realizes the interconnection of control network and
information network and has a broad application prospect in the
agricultural water saving irrigation.
Informatique [cs]
