Modeling Design and Application of Low-Temperature Plasma Treatment Test Stand for Seeds before Sowing
Stimulation with a low-temperature plasma (LTP) can improve the seed
germination and seed adaptability to the environment. This technology
has been applied in practice, but the study level of mechanism involved
is still limited. Moreover, the treatment devices in using are quite
simple. The paper focuses on the modeling design and application of the
LTP treatment test stand for seeds before sowing. Numerous experimental
LTP treatment on crop seeds and forage grass seeds will be conducted to
find out the optimal dose used in the treatment. Another advanced method
of this modeling is data collecting and intelligent monitoring system
designed in, therefore all key process parameters can be under control
during treatment period. At the same time, the modeling design will
provide technical support for large-scale manufacturing of seed
treatment devices.
