Abstract : To realize in vivo, real-time, non-invasive and in-situ detection
analysis on the dynamic changes of ion flows in plant tissues, organs,
cells and others under natural conditions, this paper designed
three-dimensional electronic control motion platform of high-accuracy so
as to realize the highly-accurate motion control in micron order and
enable glass microelectrode to measure the plant tissues, organs and
cells in its best state. The apparatus requires the portable design, so
this paper chose the ion flow detection device with small size and high
accuracy and micro integrative drive control module. Also graphical
programming software LabVIEW was utilized to send serial port commands
so as to realize the accurate and reciprocating motion of glass
microelectrode at different positions and further accurately detect the
plant microscopic dynamic ion flow parameter. The test showed that this
control software could realize highly-accurate positioning of
0.6371μm/step in
three-dimensional space and the software system could operate steadily,
which provides strong supports for the plant microscopic ion flow
detection.
https://hal.inria.fr/hal-01220945 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, October 27, 2015 - 10:17:11 AM Last modification on : Sunday, December 23, 2018 - 1:52:02 PM Long-term archiving on: : Thursday, January 28, 2016 - 10:39:07 AM
