Building a low-energy, transparent optical wide area network with multipaths - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Optical Communications and Networking Année : 2013
We propose an all-optical networking solution for a wide area network built on shared multipoint-to-multipoint lightpaths that, for short, we call "multipaths." A multipath concentrates the traffic of a group of source nodes on a wavelength channel using an adapted medium access control protocol and multicasts this traffic to a group of destination nodes that extract their own data from the confluent stream. The proposed network can be built using existing components and appears less complex and more efficient in terms of energy consumption than alternatives like optical packet switching and optical burst switching. The paper presents the multipath architecture and compares its energy consumption to that of a classical router-based Internet service provider network. A flow-aware dynamic bandwidth allocation algorithm is proposed and shown to have excellent performance in terms of throughput and delay.
Fichier non déposé
hal-01221577 , version 1 (28-10-2015)
Cuda Davide, Indre Raluca-Maria, James Roberts, Rouzic Esther Le. Building a low-energy, transparent optical wide area network with multipaths. Journal of Optical Communications and Networking, 2013, 5 (1), pp.56-67. ⟨10.1364/JOCN.5.000056⟩. ⟨hal-01221577⟩
77 Consultations
0 Téléchargements
