Towards an automatic tool for multi-scale model derivation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
This paper reports recent advances in the development of a symbolic asymptotic mod-eling software package, called MEMSALab, which will be used for automatic generation of asymptotic models for arrays of micro and nanosystems. More precisely, a model is a partial differential equation and an asymptotic method approximate it by another partial differential equation which can be numerically simulated in a reasonable time. The challenge consists in taking into account a wide range of different physical features and geometries e.g. thin structures, periodic structures, multiple nested scales etc. The main purpose of this software is to construct models incrementally so that model features can be included step by step. This idea, conceptualized under the name "by-extension-combination", is presented in detail for the first time.
long-version-michel.pdf (942.07 Ko) Télécharger le fichier
hal-01223141 , version 1 (05-11-2015)
  • HAL Id : hal-01223141 , version 1
Walid Belkhir, Nicolas Ratier, Duy Duc Nguyen, Bin Yang, Michel Lenczner, et al.. Towards an automatic tool for multi-scale model derivation. 2015. ⟨hal-01223141⟩
182 Consultations
76 Téléchargements
