Feature-based shape transformation for polyhedral objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1994
Anne Verroust
A new technique is presented for computing transformations between polyhedral objects. Here, the correspondence and the interpolation problems are considered jointly. The approach gives the animator high level control of the shape transformation by providing natural speciication and interaction.
eurogwas94.pdf (389.43 Ko) Télécharger le fichier
hal-01224856 , version 1 (05-11-2015)
  • HAL Id : hal-01224856 , version 1
Francis Lazarus, Anne Verroust. Feature-based shape transformation for polyhedral objects. Fifth Eurographics Workshop on Animation and Simulation, Sep 1994, Oslo, Norway. ⟨hal-01224856⟩
Collections
INRIA INRIA2
51 Consultations
93 Téléchargements
