Abstract : The paper presents an implementation for computer-aided design with dimensional parameters. The approach is based on the use of an expert system to uncouple constraint equations, and to find a possible sequence for the computation of the geometric elements for given dimension values. A set of rules for the expert system is described that solves the problem for 2D designs. The method is illustrated with an example design.
https://hal.inria.fr/hal-01224895
Contributeur : Anne Verroust-Blondet
Soumis le : mardi 10 novembre 2015 - 10:10:17
Dernière modification le : mardi 24 avril 2018 - 17:20:10
Document(s) archivé(s) le : vendredi 12 février 2016 - 17:00:46
