Orchestrating Masses of Sensors: A Design-Driven Development Approach
This paper proposes a design-driven development approach that is dedicated to the domain of orchestration of masses of sensors. The developer declares what an application does using a domain-specific language (DSL). Our compiler processes domain-specific declarations to generate a customized programming framework that guides and supports the programming phase.
