Journal articles
Parasite-Parasite Interactions in the Wild: How To Detect Them?
Eléonore Hellard 1 David Fouchet 1 Fabrice Vavre 2, 3 Dominique Pontier
1 Ecoépidémiologie évolutionniste
Département écologie évolutive [LBBE]
3 Génétique et évolution des interactions hôtes-parasites
GINSENG - Département génétique, interactions et évolution des génomes [LBBE]
Abstract : Inter-specific interactions between parasites impact on parasite intra-hostdynamics, host health, and disease management. Identifying and understandinginteraction mechanisms in the wild is crucial for wildlife disease management.It is however complex because several scales are interlaced. Parasite–parasite interactions are likely to occur via mechanisms at the within-host level,but also at upper levels (host population and community). Furthermore, interactionsoccurring at one level of organization spread to upper levels throughcascade effects. Even if cascade effects are important confounding factors, weargue that we can also benefit from them because upper scales often provide away to survey a wider range of parasites at lower cost. New protocols andtheoretical studies (especially across scales) are necessary to take advantage ofthis opportunity.
Document type :
Journal articles
Complete list of metadata
Cited literature [80 references]  Display  Hide  Download
https://hal.inria.fr/hal-01227711
Contributor : Marie-France Sagot Connect in order to contact the contributor
Submitted on : Thursday, June 29, 2017 - 12:07:53 PM
Last modification on : Tuesday, May 17, 2022 - 2:50:02 PM
Long-term archiving on: : Thursday, January 18, 2018 - 2:40:13 AM
File
hellard2015.pdf
Identifiers
  • HAL Id : hal-01227711, version 1
  • PUBMED : 26440785
Collections
Citation
Eléonore Hellard, David Fouchet, Fabrice Vavre, Dominique Pontier. Parasite-Parasite Interactions in the Wild: How To Detect Them?. Trends in Parasitology, Elsevier, 2015. ⟨hal-01227711⟩
Share
Metrics
Record views
262
Files downloads
758
