New interface
Journal articles
A generative probabilistic model and discriminative extensions for brain lesion segmentation – with application to tumor and stroke
Abstract : We introduce a generative probabilistic model for segmentation of brain lesions in multi-dimensional images that generalizes the EM segmenter, a common approach for modelling brain images using Gaussian mixtures and a probabilistic tissue atlas that employs expectation-maximization (EM) to estimate the label map for a new image. Our model augments the probabilistic atlas of the healthy tissues with a latent atlas of the lesion. We derive an estimation algorithm with closed-form EM update equations. The method extracts a latent atlas prior distribution and the lesion posterior distributions jointly from the image data. It delineates lesion areas individually in each channel, allowing for differences in lesion appearance across modalities, an important feature of many brain tumor imaging sequences. We also propose discriminative model extensions to map the output of the generative model to arbitrary labels with semantic and biological meaning, such as “tumor core” or “fluid-filled structure”, but without a one-to-one correspondence to the hypo- or hyper-intense lesion areas identified by the generative model. We test the approach in two image sets: the publicly available BRATS set of glioma patient scans, and multimodal brain images of patients with acute and subacute ischemic stroke. We find the generative model that has been designed for tumor lesions to generalize well to stroke images, and the generative-discriminative model to be one of the top ranking methods in the BRATS evaluation.
Document type :
Journal articles
Complete list of metadata
Cited literature [73 references]  Display  Hide  Download
https://hal.inria.fr/hal-01230846
Contributor : Bjoern Menze Connect in order to contact the contributor
Submitted on : Wednesday, November 25, 2015 - 3:13:16 PM
Last modification on : Friday, November 18, 2022 - 9:25:02 AM
Long-term archiving on: : Friday, April 28, 2017 - 2:06:08 PM
File
manuscript.pdf
Identifiers
  • HAL Id : hal-01230846, version 1
Collections
Citation
Bjoern H Menze, Koen van Leemput, Danial Lashkari, Tammy Riklin-Raviv, Ezequiel Geremia, et al.. A generative probabilistic model and discriminative extensions for brain lesion segmentation – with application to tumor and stroke. IEEE Transactions on Medical Imaging, 2015. ⟨hal-01230846⟩
Share
Metrics
Record views
453
Files downloads
352
