Amplitude and latency of EEG Beta activity during real movements, discrete and continuous motor imageries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2015
Motor imagery (MI) modifies the neural activity within the primary sensorimotor areas of the cortex in a similar way to a real movement. More precisely, beta oscillations (18-­‐25 Hz), which are often considered as a sensorimotor rhythm , show that the amplitude of brain oscillations is modulated before , during and after a MI. In most MI-based BCI experimental paradigm, subjects realize continuous MI, i.e a prolonged intention of movement, during a time window of a few seconds with the objective to increase the detection of ERD and ERS. However, when the subjects imagine a succession of movements, several ERD and ERS are generated, with lower amplitudes than those elicited by a single MI. Here, we employ a simple short MI to detect the ERD and the ERS.
Berstein15_poster_Rimbert (1).pdf (1.16 Mo) Télécharger le fichier
hal-01231404 , version 1 (20-11-2015)
  • HAL Id : hal-01231404 , version 1
Sébastien Rimbert, Laurent Bougrain, Cecilia Lindig-León, Guillaume Serrière, Francesco Giovannini, et al.. Amplitude and latency of EEG Beta activity during real movements, discrete and continuous motor imageries. Bernstein Conference 2015, Sep 2015, Bernstein, Germany. ⟨hal-01231404⟩
227 Consultations
143 Téléchargements
