A Framework For The Evaluation Of Measurement-based Timing Analyses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A key issue with Worst-Case Execution Time (WCET) analyses is the evaluation of the tightness and soundness of the results produced. In the absence of a ground truth, i.e. the Actual WCET (AWCET), such evaluations rely on comparison between di↵erent estimates or observed values. In this paper, we introduce a framework for the evaluation of measurement-based timing analyses. This framework uses abstract models of synthetic tasks to provide realisticexecution time data as input to the analyses, while ensuring that a corresponding AWCET can be computed. The effectiveness of the framework is demonstrated by evaluating the impact of imperfect structural coverage on an existing measurement-based probabilistic timing analysis.
Fichier non déposé
hal-01231710 , version 1 (20-11-2015)
  • HAL Id : hal-01231710 , version 1
Benjamin Lesage, David Griffin, Frank Soboczenski, Iain Bate, Robert Davis. A Framework For The Evaluation Of Measurement-based Timing Analyses. 23rd International Conference on Real-Time Networks and Systems (RTNS 2015), Nov 2015, Lille, France. pp.35-44. ⟨hal-01231710⟩
175 Consultations
0 Téléchargements
