Abstract : Programming frameworks are an accepted fixture in the
object-oriented world, motivated by the need for code reuse,
developer guidance, and restriction. A new trend is emerging where
frameworks require domain experts to provide declarations using a
domain-specific language (DSL), influencing the structure and
behaviour of the resulting application. These mechanisms address
concerns such as user privacy. Although many popular open platforms
such as Android are based on declaration-driven frameworks, current
implementations provide ad hoc and narrow solutions to concerns
raised by their openness to non-certified developers. Most widely
used frameworks fail to address serious privacy leaks, and provide
the user with little insight into application behaviour.
To address these shortcomings, we show that declaration-driven
frameworks can limit privacy leaks, as well as guide developers,
independently from the underlying programming paradigm. To do so,
we identify concepts that underlie declaration-driven frameworks,
and apply them systematically to both an object-oriented language,
Java, and a dynamic functional language, Racket. The resulting
programming framework generators are used to develop a prototype
mobile application, illustrating how we mitigate a common class of
privacy leaks. Finally, we explore the possible design choices and
propose development principles for developing domain-specific
language compilers to produce frameworks, applicable across a
spectrum of programming paradigms.
