Detection of buried mosaics in plaster layers by square pulse thermography: laboratory study on different shape distribution samples - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work deals with the detection of non-emergent small structures like mosaic, hidden under a plaster layer, with various spatial layout and nature. A first feasibility study using a unique sample for one type of defective patchworks was presented in [1]. In this previous study analysis was mainly focused on thermal contrast [2]. In the present study, square pulse thermography experiments were carried out, in laboratory conditions, on different samples. Figure 1 show a view of the hidden structures and the laboratory set up. Figure 1 View of some samples and of experimental set up in laboratory At the final 9 different samples were studied. For 8 configurations thermal numerical simulations were also realized under FLUENT™. They were used to generate simulated infrared thermal sequences. Three post processing approach [3-5] by PPT, SVD and Polynomial analysis were conducted on this experimental and simulated data set. Results obtained are analyzed and discussed. Finally, influence of IR camera used will be also addressed and discussed in the dissertation.
CP0086.pdf (123.2 Ko) Télécharger le fichier
hal-01237384 , version 1 (03-12-2015)
  • HAL Id : hal-01237384 , version 1
A Mazioud, L Ibos, Jean Dumoulin. Detection of buried mosaics in plaster layers by square pulse thermography: laboratory study on different shape distribution samples. QIRT ASIA 2015, Apr 2015, Mahabalipuram, India. ⟨hal-01237384⟩
130 Consultations
64 Téléchargements
