New interface
Journal articles
Using Formal Grammars to Predict I/O Behaviors in HPC: the Omnisc'IO Approach
Abstract : The increasing gap between the computation performance of post-petascale machines and the performance of their I/O subsystem has motivated many I/O optimizations including prefetching, caching, and scheduling. In order to further improve these techniques, modeling and predicting spatial and temporal I/O patterns of HPC applications as they run has become crucial. In this paper we present Omnisc'IO, an approach that builds a grammar-based model of the I/O behavior of HPC applications and uses it to predict when future I/O operations will occur, and where and how much data will be accessed. To infer grammars, Omnisc'IO is based on StarSequitur, a novel algorithm extending Nevill-Manning's Sequitur algorithm. Omnisc'IO is transparently integrated into the POSIX and MPI I/O stacks and does not require any modification in applications or higher-level I/O libraries. It works without any prior knowledge of the application and converges to accurate predictions of any N future I/O operations within a couple of iterations. Its implementation is efficient in both computation time and memory footprint.
Complete list of metadata
Cited literature [31 references]  Display  Hide  Download
https://hal.inria.fr/hal-01238103
Contributor : Shadi Ibrahim Connect in order to contact the contributor
Submitted on : Friday, December 4, 2015 - 12:15:32 PM
Last modification on : Friday, November 18, 2022 - 9:23:40 AM
Long-term archiving on: : Saturday, April 29, 2017 - 5:17:38 AM
File
paper.pdf
Identifiers
Citation
Matthieu Dorier, Shadi Ibrahim, Gabriel Antoniu, Robert Ross. Using Formal Grammars to Predict I/O Behaviors in HPC: the Omnisc'IO Approach. IEEE Transactions on Parallel and Distributed Systems, 2016, ⟨10.1109/TPDS.2015.2485980⟩. ⟨hal-01238103⟩
Share
Metrics
Record views
452
Files downloads
232
