Statistical Model Checking for SystemC Models
Transaction-level modeling with SystemC has been very successful in describing the behavior of embedded systems by providing high-level executable models, in which many of them have an inherent probabilistic behavior, i.e., random data, unreliable components. It is crucial to evaluate the quantitative and qualitative analysis of the probability of the system properties. Such analysis can be conducted by constructing a formal model of the system and using probabilistic model checking. However, this method is infeasible for large and complex systems due to the state space explosion. In this paper, we demonstrate the successful use of statistical model checking to carry out such analysis directly from large SystemC models and allows designers to express a wide range of useful properties.
