HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Hybrid Control of a Bioreactor with Quantized Measurements
Francis Mairet 1 Jean-Luc Gouzé 1
1 BIOCORE - Biological control of artificial ecosystems
LOV - Laboratoire d'océanographie de Villefranche, CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique
Abstract : We consider the problem of global stabilization of an unstable bioreactor model (e.g. for anaerobic digestion), when the measurements are discrete and in finite number (" quantized "), with control of the dilution rate. The measurements define regions in the state space, and they can be perfect or uncertain (i.e. without or with overlaps). We show that, under appropriate assumptions, a quantized control may lead to global stabilization: trajectories have to follow some transitions between the regions, until the final region where they converge toward the reference equilibrium. On the boundary between regions, the solutions are defined as a Filippov differential inclusion. If the assumptions are not fulfilled, sliding modes may appear, and the transition graphs are not deterministic.
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-01239387
Contributor : Jean-Luc Gouzé Connect in order to contact the contributor
Submitted on : Monday, December 7, 2015 - 5:09:48 PM
Last modification on : Thursday, January 20, 2022 - 5:28:33 PM
Long-term archiving on: : Tuesday, March 8, 2016 - 4:32:52 PM
File
hybrid_bioreactor_vf_short.pdf
Identifiers
Citation
Francis Mairet, Jean-Luc Gouzé. Hybrid Control of a Bioreactor with Quantized Measurements. IEEE Transactions on Automatic Control, Institute of Electrical and Electronics Engineers, 2016, 61 (5), pp.1385 - 1390 ⟨10.1109/TAC.2015.2471735⟩. ⟨hal-01239387⟩
Share
Metrics
Record views
357
Files downloads
206
