An efficient SEM algorithm for Gaussian Mixtures with missing data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The missing data problem is well-known for statisticians but its frequency increases with the growing size of modern datasets. In Gaussian model-based clustering, the EM algorithm easily takes into account such data by dealing with two kinds of latent levels: the components and the variables. However, the quite familiar degeneracy problem in Gaussian mixtures is aggravated during the EM runs. Indeed, numerical experiments clearly reveal that degeneracy is quite slow and also more frequent than with complete data. In practice, such situations are difficult to detect efficiently. Consequently, degenerated solutions may be confused with valuable solutions and, in addition, computing time may be wasted through wrong runs. A theoretical and practical study of the degeneracy will be presented. Moreover a simple condition on the latent partition to avoid degeneracy will be exhibited. This condition is used in a constrained version of the Stochastic EM (SEM) algorithm. Numerical experiments on real and simulated data illustrate the good behaviour of the proposed algorithm.
slidesERCIM.pdf (398.91 Ko) Télécharger le fichier
hal-01242588 , version 1 (14-12-2015)
  • HAL Id : hal-01242588 , version 1
Vincent Vandewalle, C Biernacki. An efficient SEM algorithm for Gaussian Mixtures with missing data. 8th International Conference of the ERCIM WG on Computational and Methodological Statistics, Dec 2015, Londres, United Kingdom. ⟨hal-01242588⟩
188 Consultations
33 Téléchargements
