Eventually Consistent Register Revisited - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In order to converge in the presence of concurrent updates, modern eventually consistent replication systems rely on causality information and operation semantics. It is relatively easy to use semantics of high-level operations on replicated data structures, such as sets, lists, etc. However, it is difficult to exploit semantics of operations on registers, which store opaque data. In existing register designs, concurrent writes are resolved either by the application, or by arbitrating them according to their timestamps. The former is complex and may require user intervention, whereas the latter causes arbitrary updates to be lost. In this work, we identify a register construction that generalizes existing ones by combining runtime causality ordering, to identify concurrent writes, with static data semantics, to resolve them. We propose a simple conflict resolution template based on an application-predefined order on the domain of values. It eliminates or reduces the number of conflicts that need to be resolved by the user or by an explicit application logic. We illustrate some variants of our approach with use cases, and how it generalizes existing designs.
Autre [cs.OH]
mvreg_arXiv.pdf (305.76 Ko) Télécharger le fichier
bug-run (1).pdf (43.22 Ko) Télécharger le fichier
bug-run.pdf (43.22 Ko) Télécharger le fichier
lww-run.pdf (37.81 Ko) Télécharger le fichier
lww-run2 (1).pdf (37.99 Ko) Télécharger le fichier
lww-run2.pdf (37.99 Ko) Télécharger le fichier
hal-01242700 , version 1 (13-12-2015)
Copyright (Tous droits réservés)
Marek Zawirski, Carlos Baquero, Annette Bieniusa, Nuno Preguiça, Marc Shapiro. Eventually Consistent Register Revisited. Int. W. on Principles and Practice of Consistency for Distributed Data (PaPoC), ACM Sigops / EuroSys, Apr 2016, London, United Kingdom. pp.7, ⟨10.1145/2911151.2911157⟩. ⟨hal-01242700⟩
611 Consultations
375 Téléchargements
