JCorpusRecorder - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2015
JCorpusRecorder
JCorpusRecorder is a software for the recording of audio corpora. It provides an easy tool to record with a microphone. The audio input gain is controlled during the recording. From a list of sentences, the output is a set of wav files automatically renamed according to textual information given in input (nationality, speaker language, gender...). An easy to use tagging allows for displaying a textual/visual/audio context of the sentence to pronounce. Several text encodings are enabled (for Chinese langage for instance). This software is suitable for recording sentences with information to guide the speaker. The sentences can be presented randomly. The recording (input/output) can be done unitil 8 channels (for Linux and 2 for Windows). The software is developed in Java.
Fichier non déposé
hal-01244553 , version 1 (15-12-2015)
  • HAL Id : hal-01244553 , version 1
Vincent Colotte, Emilien Casano. JCorpusRecorder. [Technical Report] Université de Lorraine. 2015. ⟨hal-01244553⟩
167 Consultations
1 Téléchargements
