Accelerated, Sparsity-Aware Generalizations of Classical Algorithms for TomoPIV - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We set up a generalized optimization framework for the classical Row Action Methods, otherwise customarily employed in the TomoPIV community. This scheme allows us to bypass known caveats of the algebraic programs. The so-enhance methods enable i) handling explicit constraints on the signal; ii) accelerating the rates of convergence. Comparative numerical simulations reveal superior performance of the latter with no inflation of the complexity.
Barbu2015a.pdf (189.51 Ko) Télécharger le fichier
hal-01245014 , version 1 (16-12-2015)
hal-01245014 , version 2 (22-02-2016)
  • HAL Id : hal-01245014 , version 2
Ioana Barbu, Cédric Herzet. Accelerated, Sparsity-Aware Generalizations of Classical Algorithms for TomoPIV. PIV15, The 11th International Symposium on Particle Image Velocimetry, Sep 2015, Santa Barbara, California, United States. ⟨hal-01245014v2⟩
194 Consultations
109 Téléchargements
