New interface
Journal articles
Improving the energy efficiency of software-defined backbone networks
Abstract : The continuous growth of traffic and the energy consumption of network equipments can limit the deployment of large-scale distributed infrastructure. This work aims to improve the energy efficiency of backbone networks by dynamically adjusting the number of active links according to network load. We propose an intra-domain software-defined network approach to select and turn off a subset of links. The SPRING protocol (a.k.a. segment routing) is used to make our algorithms converge faster. The algorithms—implemented and evaluated using the OMNET++ discrete event simulator—can achieve energy savings of around 44 % when considering real backbone networks.
Document type :
Journal articles
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01246376
Contributor : Radu Carpa Connect in order to contact the contributor
Submitted on : Friday, November 10, 2017 - 3:36:36 PM
Last modification on : Tuesday, October 25, 2022 - 4:23:27 PM
Long-term archiving on: : Sunday, February 11, 2018 - 2:34:08 PM
File
PNET2015.pdf
Identifiers
Collections
Citation
Radu Carpa, Olivier Glück, Laurent Lefèvre, Jean-Christophe Mignot. Improving the energy efficiency of software-defined backbone networks. Photonic Network Communications, 2015, 30 (3), pp.337-347. ⟨10.1007/s11107-015-0552-9⟩. ⟨hal-01246376⟩
Share
Metrics
Record views
205
Files downloads
364
