Practical domain-specific debuggers using the Moldable Debugger framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Languages, Systems and Structures Année : 2015
Understanding the run-time behavior of software systems can be a challenging activity. Debuggers are an essential category of tools used for this purpose as they give developers direct access to the running systems. Nevertheless, traditional debuggers rely on generic mechanisms to introspect and interact with the running systems, while developers reason about and formulate domain-specific questions using concepts and abstractions from their application domains. This mismatch creates an abstraction gap between the debugging needs and the debugging support leading to an inefficient and error-prone debugging effort, as developers need to recover concrete domain concepts using generic mechanisms. To reduce this gap, and increase the efficiency of the debugging process, we propose a framework for developing domain-specific debuggers, called the Moldable Debugger, that enables debugging at the level of the application domain. The Moldable Debugger is adapted to a domain by creating and combining domain-specific debugging operations with domain-specific debugging views, and adapts itself to a domain by selecting, at run time, appropriate debugging operations and views. To ensure the proposed model has practical applicability (i.e., can be used in practice to build real debuggers), we discuss, from both a performance and usability point of view, three implementation strategies. We further motivate the need for domain-specific debugging, identify a set of key requirements and show how our approach improves debugging by adapting the debugger to several domains.
Chis15c-PracticalDomainSpecificDebuggers.pdf (3.18 Mo) Télécharger le fichier
hal-01247941 , version 1 (23-12-2015)
Andrei Chiş, Marcus Denker, Tudor Gîrba, Oscar Nierstrasz. Practical domain-specific debuggers using the Moldable Debugger framework. Computer Languages, Systems and Structures, 2015, 44 (Part A), pp. 89-113. ⟨10.1016/j.cl.2015.08.005⟩. ⟨hal-01247941⟩
412 Consultations
301 Téléchargements
