Preemptive Uniprocessor Scheduling of Mixed-Criticality Sporadic Task Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the ACM (JACM) Année : 2015
Systems in many safety-critical application domains are subject to certification requirements. For any given system, however, it may be the case that only a subset of its functionality is safety-critical and hence subject to certification; the rest of the functionality is non-safety-critical and does not need to be certified, or is certified to lower levels of assurance. The certification-cognizant runtime scheduling of such mixed-criticality systems is considered. An algorithm called EDF-VD (for Earliest Deadline First with Virtual Deadlines) is presented: this algorithm can schedule systems for which any number of criticality levels are defined. Efficient implementations of EDF-VD, as well as associated schedulability tests for determining whether a task system can be correctly scheduled using EDF-VD, are presented. For up to 13 criticality levels, analyses of EDF-VD, based on metrics such as processor speedup factor and utilization bounds, are derived, and conditions under which EDF-VD is optimal with respect to these metrics are identified. Finally, two extensions of EDF-VD are discussed that enhance its applicability. The extensions are aimed at scheduling a wider range of task sets, while preserving the favorable worst-case resource usage guarantees of the basic algorithm.
baruah2015.pdf (370.92 Ko) Télécharger le fichier
hal-01249091 , version 1 (29-06-2017)
Sanjoy Baruah, Vincenzo Bonifaci, Gianlorenzo d'Angelo, Haohan Li, Alberto Marchetti-Spaccamela, et al.. Preemptive Uniprocessor Scheduling of Mixed-Criticality Sporadic Task Systems. Journal of the ACM (JACM), 2015, 62 (2), pp.14. ⟨10.1145/2699435⟩. ⟨hal-01249091⟩
Collections
INRIA INRIA2
89 Consultations
202 Téléchargements
