Java-Meets Eclipse - An IDE for Teaching Java Following the Object-later Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we introduce a new Eclipse-based IDE for teaching Java following the object-later approach. In particular, this IDE allows the programmer to write code in Java--, a smaller version of the Java language that does not include object-oriented features. For the implementation of this language we used Xtext, an Eclipse framework for implementing Domain Specific Languages; besides the compiler mechanisms, Xtext also allows to easily implement all the IDE tooling mechanisms in Eclipse. By using Xtext we were able to provide an implementation of Java-- with all the powerful features available when using an IDE like Eclipse (including debugging, automatic building, and project wizards). With our implementation, it is also straightforward to create self-assessment exercises for students, which are integrated in Eclipse and JUnit.
Mots clés
ICSOFT-PT_2015_9.pdf (1.03 Mo) Télécharger le fichier
hal-01249109 , version 1 (04-07-2017)
Lorenzo Bettini, Pierluigi Crescenzi. Java-Meets Eclipse - An IDE for Teaching Java Following the Object-later Approach . International Conference on Software Paradigm Trend (ICSOFT-PT), Sep 2015, Colmar, France. pp.31-42, ⟨10.5220/0005512600310042⟩. ⟨hal-01249109⟩
Collections
INRIA INRIA2
111 Consultations
395 Téléchargements
