New interface
Conference papers
Diversity-driven selection of exploration strategies in multi-armed bandits
Fabien Benureau 1, * Pierre-Yves Oudeyer 1
* Corresponding author
Abstract : We consider a scenario where an agent has multiple available strategies to explore an unknown environment. For each new interaction with the environment, the agent must select which exploration strategy to use. We provide a new strategy-agnostic method that treat the situation as a Multi-Armed Bandits problem where the reward signal is the diversity of effects that each strategy produces. We test the method empirically on a simulated planar robotic arm, and establish that the method is both able discriminate between strategies of dissimilar quality, even when the differences are tenuous, and that the resulting performance is competitive with the best fixed mixture of strategies.
Complete list of metadata
Cited literature [36 references]  Display  Hide  Download
https://hal.inria.fr/hal-01251060
Contributor : Pierre-Yves Oudeyer Connect in order to contact the contributor
Submitted on : Tuesday, January 5, 2016 - 3:38:24 PM
Last modification on : Saturday, June 25, 2022 - 9:09:52 PM
Long-term archiving on: : Thursday, April 7, 2016 - 3:28:44 PM
File
BenureauOudeyerIcdl2015.pdf
Identifiers
Collections
Citation
Fabien Benureau, Pierre-Yves Oudeyer. Diversity-driven selection of exploration strategies in multi-armed bandits. IEEE International Conference on Development and Learning and Epigenetic Robotics, Aug 2015, Providence, United States. ⟨10.1109/DEVLRN.2015.7346130⟩. ⟨hal-01251060⟩
Share
Metrics
Record views
136
Files downloads
154
