HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Anisotropic Delaunay Mesh Generation
Jean-Daniel Boissonnat 1, 2 Camille Wormser 1 Mariette Yvinec 1
1 GEOMETRICA - Geometric computing
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Saclay - Ile de France
2 DATASHAPE - Understanding the Shape of Data
Abstract : Anisotropic meshes are triangulations of a given domain in the plane or in higher dimensions, with elements elongated along prescribed directions. Anisotropic trian-gulations are known to be well suited for interpolation of functions or solving PDEs. Assuming that the anisotropic shape requirements for mesh elements are given through a metric field varying over the domain, we propose a new approach to anisotropic mesh generation, relying on the notion of anisotropic Delaunay meshes. An anisotropic De-launay mesh is defined as a mesh in which the star of each vertex v consists of simplices that are Delaunay for the metric associated to vertex v. This definition works in any dimension and allows to define a simple refinement algorithm. The algorithm takes as input a domain and a metric field and provides, after completion, an anisotropic mesh whose elements are sized and shaped according to the metric field.
Document type :
Journal articles
Complete list of metadata
Cited literature [40 references]  Display  Hide  Download
https://hal.inria.fr/hal-01251628
Contributor : Jean-Daniel Boissonnat Connect in order to contact the contributor
Submitted on : Monday, October 24, 2016 - 11:08:40 PM
Last modification on : Wednesday, February 2, 2022 - 3:55:20 PM
mainV4.pdf
Identifiers
Citation
Jean-Daniel Boissonnat, Camille Wormser, Mariette Yvinec. Anisotropic Delaunay Mesh Generation. SIAM Journal on Computing, Society for Industrial and Applied Mathematics, 2015, 44 (2), pp.467-512. ⟨10.1137/140955446⟩. ⟨hal-01251628v2⟩
Share
Metrics
Record views
368
Files downloads
180
