Static Analysis of OpenStream Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Albert Cohen
Alain Darte
This paper studies the applicability of polyhedral techniques to the parallel language Open- Stream [25]. When applicable, polyhedral techniques are invaluable for compile-time debugging and for generating efficient code well suited to a target architecture. OpenStream is a two-level language in which a control program directs the initialization of parallel task instances that communicate through streams, with possibly multiple writers and readers. It has a fairly complex semantics in its most general setting, but we restrict ourselves to the case where the control program is sequential, which is representative of the majority of the OpenStream applications. This restriction offers deterministic concurrency by construction, but deadlocks are still possible. We show that, if the control program is polyhedral, one may statically compute, for each task instance, the read and write indices to each of its streams, and thus reason statically about the dependences among task instances (the only scheduling constraints in this polyhedral subset). These indices may be polynomials of arbitrary degree, thus requiring to extend to polynomials the standard polyhedral techniques for dependence analysis, scheduling, and deadlock detection. Modern SMT allow to solve polynomial problems, albeit with no guarantee of success; the approach of Feautrier [10] may offer an alternative solution. We also establish two important results related to deadlocks in OpenStream: 1) a characterization of deadlocks in terms of dependence paths, which implies that streams can be safely bounded as soon as a schedule exists with such sizes, 2) the proof that deadlock detection is undecidable, even for polyhedral OpenStream.
Fichier non déposé
hal-01251845 , version 1 (06-01-2016)
  • HAL Id : hal-01251845 , version 1
Albert Cohen, Alain Darte, Paul Feautrier. Static Analysis of OpenStream Programs. 6th International Workshop on Polyhedral Compilation Techniques (IMPACT'16), held with HIPEAC'16, Michelle Strout and Tomofumi Yuki, Jan 2016, Prague, Czech Republic. ⟨hal-01251845⟩
366 Consultations
0 Téléchargements
