STS-k: A Multilevel Sparse Triangular Solution Scheme for NUMA Multicores
We consider techniques to improve the performance of parallel sparse triangular solution on non-uniform memory architecture multicores by extending earlier coloring and level set schemes for single-core multiprocessors. We develop STS-k, where k represents a small number of transformations for la-tency reduction from increased spatial and temporal locality of data accesses. We propose a graph model of data reuse to inform the development of STS-k and to prove that computing an optimal cost schedule is NP-complete. We observe significant speed-ups with STS-3 on 32-core Intel Westmere-Ex and 24-core AMD 'MagnyCours' processors. Incremental gains solely from the 3-level transformations in STS-3 for a fixed ordering, correspond to reductions in execution times by factors of 1.4(Intel) and 1.5(AMD) for level sets and 2(In-tel) and 2.2(AMD) for coloring. On average, execution times are reduced by a factor of 6(Intel) and 4(AMD) for STS-3 with coloring compared to a reference implementation using level sets.
