Abstract : Subspace clustering is recognized as a more general and difficult task than standard clustering since it requires to identify not only objects sharing similar feature values but also the various subspaces where these similarities appear. Many approaches have been investigated for subspace clustering in the literature using various clustering paradigms. In this paper, we present Chameleoclust, an evolutionary subspace clustering algorithm that incorporates a genome having an evolvable structure. The genome is a coarse grained genome defined as a list of tuples (the "genes"),
each tuple containing numbers. These tuples are mapped at the phenotype level to denote core point locations in different dimensions, which are then used to collectively build the subspace clusters, by grouping the data around the core points. The algorithm has been assessed using a reference framework for subspace clustering evaluation, and compared to state-of-the-art algorithms on both real and synthetic datasets. The results obtained with the Chameleoclust algorithm show that evolution of evolution, through an evolvable genome structure, is usefull to solve a difficult problem such as subspace clustering.
