Journal articles
Dependence of tropical eigenspaces
Adi Niv 1, 2 Louis Rowen 3
1 TROPICAL - TROPICAL
CMAP - Centre de Mathématiques Appliquées - Ecole Polytechnique, Inria Saclay - Ile de France
2 MAXPLUS - Max-plus algebras and mathematics of decision
Abstract : We study the pathology that causes tropical eigenspaces of distinct su-pertropical eigenvalues of a non-singular matrix A, to be dependent. We show that in lower dimensions the eigenvectors of distinct eigenvalues are independent, as desired. The index set that differentiates between subsequent essential monomials of the characteristic polynomial, yields an eigenvalue λ, and corresponds to the columns of adj(A + λI) from which the eigenvectors are taken. We ascertain the cause for failure in higher dimensions, and prove that independence of the eigenvectors is recovered in case the " difference criterion " holds, defined in terms of disjoint differences between index sets of subsequent coefficients. We conclude by considering the eigenvectors of the matrix A ∇ := 1 det(A) adj(A) and the connection of the independence question to generalized eigenvectors.
Document type :
Journal articles
Complete list of metadata
Cited literature [29 references]  Display  Hide  Download
https://hal.inria.fr/hal-01253422
Contributor : Adi Niv Connect in order to contact the contributor
Submitted on : Sunday, January 10, 2016 - 1:22:58 PM
Last modification on : Friday, July 8, 2022 - 10:08:39 AM
Long-term archiving on: : Monday, April 11, 2016 - 10:54:23 AM
File
tropeigenspaces.pdf
Identifiers
Citation
Adi Niv, Louis Rowen. Dependence of tropical eigenspaces. Communications in Algebra, Taylor & Francis, 2017, 45 (3), pp. 924-942. ⟨10.1080/00927872.2016.1172603⟩. ⟨hal-01253422⟩
Share
Metrics
Record views
143
Files downloads
132
