Process Mapping onto Complex Architectures and Partitions Thereof - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Scotch software computes process-processor mappings by assigning recursively parts of the process graphs to parts of the target graphs. To date, while regular target architectures can be described using pre-coded routines, irregular architectures or parts of regular ones require O(P^2) data structures, which makes them unpractical for very big machines. We will present a new, multilevel description of target architectures that alleviates this problem, trading-off memory for run time.
presentation (1).pdf (2.84 Mo) Télécharger le fichier
hal-01253509 , version 1 (07-02-2018)
  • HAL Id : hal-01253509 , version 1
François Pellegrini, Cédric Lachat. Process Mapping onto Complex Architectures and Partitions Thereof. SIAM Conference on Computational Science & Engineering, SIAM, Mar 2015, Salt Lake City, United States. ⟨hal-01253509⟩
Collections
CNRS INRIA INRIA2
112 Consultations
16 Téléchargements
