Physical and Perceptual Independence of Ultrasonic Vibration and Electrovibration for Friction Modulation - Archive ouverte HAL Access content directly
Journal Articles IEEE Transactions on Haptics (ToH) Year : 2015
(1) , (2) , (2) , (1) , (2) , (3)
1
2
3
—Two different principles are available to modulate the user perceived roughness of a surface: electrovibration and ultrasonic vibration of a plate. The former enhances the perceived friction coefficient and the latter reduces it. This paper will highlight the independence of the two effects on the physical and perceptual point of view to confirm the increased range of sensation that can be supplied by the two coupled techniques. Firstly, a tribometric analysis of the induced lateral force on the finger by the two coupled effects will be presented, then a study on the dynamic of the two effects will be reported. In the end, a psychophysical experiment on the perception of the two coupled techniques will be shown.
ToH_short_final.pdf (13.18 Mo) Télécharger le fichier
Dates and versions
hal-01253575 , version 1 (11-01-2016)
Identifiers
Cite
Eric Vezzoli, Wael Ben Messaoud, Michel Amberg, Betty Lemaire-Semail, Frédéric Giraud, et al.. Physical and Perceptual Independence of Ultrasonic Vibration and Electrovibration for Friction Modulation. IEEE Transactions on Haptics (ToH), 2015, ⟨10.1109/TOH.2015.2430353⟩. ⟨hal-01253575⟩
266 View
376 Download
Share
