New interface
Reports (Research report)
Shape Animation with Combined Captured and Simulated Dynamics
Benjamin Allain 1 Li Wang 1 Jean-Sébastien Franco 1 Franck Hetroy-Wheeler 1 Edmond Boyer 1
1 MORPHEO - Capture and Analysis of Shapes in Motion
Inria Grenoble - Rhône-Alpes, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology, LJK - Laboratoire Jean Kuntzmann
Abstract : We present a novel volumetric animation generation framework to create new types of animations from raw 3D surface or point cloud sequence of captured real performances. The framework considers as input time incoherent 3D observations of a moving shape, and is thus particularly suitable for the output of performance capture platforms. In our system, a suitable virtual representation of the actor is built from real captures that allows seamless combination and simulation with virtual external forces and objects, in which the original captured actor can be reshaped, disassembled or reassembled from user-specified virtual physics. Instead of using the dominant surface-based geometric representation of the capture, which is less suitable for volumetric effects, our pipeline exploits Centroidal Voronoi tessellation decompositions as unified volumetric representation of the real captured actor, which we show can be used seamlessly as a building block for all processing stages, from capture and tracking to virtual physic simulation. The representation makes no human specific assumption and can be used to capture and re-simulate the actor with props or other moving scenery elements. We demonstrate the potential of this pipeline for virtual reanimation of a real captured event with various unprecedented volumetric visual effects, such as volumetric distortion, erosion, morphing, gravity pull, or collisions.
Document type :
Complete list of metadata
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-01255337
Contributor : Edmond Boyer Connect in order to contact the contributor
Submitted on : Thursday, May 19, 2016 - 6:20:02 PM
Last modification on : Wednesday, October 26, 2022 - 8:14:15 AM
Identifiers
  • HAL Id : hal-01255337, version 1
  • ARXIV : 1601.01232
Collections
Citation
Benjamin Allain, Li Wang, Jean-Sébastien Franco, Franck Hetroy-Wheeler, Edmond Boyer. Shape Animation with Combined Captured and Simulated Dynamics. [Research Report] arXiv:1601.01232, ArXiv. 2016, pp.11. ⟨hal-01255337⟩
Share
Metrics
Record views
358
Files downloads
297
